configure cdp cos-extend ports
configure cdp cos-extend cos_value ports [port_list | all]
Description
This command configures COS extended support on the IP phone. This information will be sent to the IP phone from the ExtremeXOS switch by trust TLV and COS TLV.
Syntax Description
cos_value COS value range from 0 to 7.
port_list Port list separated by a comma or -";
Default
0.
Usage Guidelines
None.
The following example sets the COS TLV value as 4 for port 5 in the ExtremeXOS switch, which will be used by the IP phone to override priority received from PC or the attached device.
configure cdp cos-extend 4 ports 5
The following example sets the COS TLV value to default for port 5 in the ExtremeXOS switch.
configure cdp cos-extend 0 ports 5
This command was first available in ExtremeXOS 21.1.
Platform Availability
